need sim900 footprint protel99
faylindstrom
bdg
Hi everyone,
can somebody help me, I need sim900 footprint for protel99, I try to make it using wizard but when I make autoroute theres a violation (violation clearence constraint), can anybody help me to solve this or give me a sim900 pcb library.
thanks
Thank u very much Sherazi, ^_^
I will try that
first try to print it and check with the module pins ... and best of luck !
---------- Post added at 06:48 ---------- Previous post was at 06:47 ----------
and remember its for sim900d not sim900... if u need for sim 900 i have that for EAGLE ...
Hi Sherazi,
I have tried to use your .lib files for sim900d in DesignExplorer99SE (Protel 99) by changing the extentions to .lib but i get error "File is not recognized".
Any idea whats the problem ?
try this , i have checked it but plz check it thrice before using ... and use at ur own risk!
i dont know wheteher eagle libraries can be used in DXP by this method... the library is intended for EAGLE ....
Can you explain me how to add this files in Proteus library? I put them in Library folder but I can't find them in component library
