Need schematic of a DC-DC down converter
mpatel
Member level 4
Member level 4
Germany
I am new to power electronics. I would like to design DC-DC down converter from around 300V to either 5V or 3.3V. The output voltage should not be constantly controlled at fixed level. If the voltage level of input is reduced, the voltage level of level must also be reduced appropriately. Can anyone help with the schematic design?
Thanks and regards,
Mukesh
It depends on what you intend to use this for and the required current. If this is to be a reference for some circuit, a non-isolated voltage divider will do:
If you require this to drive some current, then you need to design an SMPS with something like TOP, TNY, DPA, VIPER, UC384x or some similar controller.
Hope this helps.
Tahmid.
    mpatel
Re: DC-DC down converter
Hi Tahmid,
Actually I want to measure the voltage level of the DC source using electronics circuit but at such high voltage electronics does not work. Therefore, I want to decrease the voltage level to 5V or 3.3 V. If the DC source voltage is lower, the output of my circuit is also lower accordingly. This is the only application.
By the way, can you give me the equation of how to derive resistors' value for different DC source voltages?
Thanks
Mukesh
Hope this helps.
Tahmid.
The formula goes:
Vout = (Vin * R2) / (R2 + R1)
For your requirement, this circuit is enough.
Hope this helps.
Tahmid.
Hi Tahmid,
But this circuit may not work at high current. I need to design to measure the voltage at very high current level, ranging from 1 A to 25 A.
Thanks
Mukesh
Tahmid said:
The formula goes:
Hope this helps.
Tahmid.
The high current is going to the load(a few kWs), not flowing through the resistors, so this is fine.
Hope this helps.
Tahmid.
Hope this helps.
Tahmid.
Yeap Agree with Tahmid! As long as your load resistance is much much smaller than the resistances of the potential divider than it should work well.
Anyway your input and output voltage is a fixed or varying voltage?
