Need sample VC++ program for interfacing parallel port
pops999
Junior Member level 3
_outb vc
i need example programe vc++ interface parallel port
please help me
thank
+tvichw32 +parallel port +example
as far as i know there's no library available in VC++.
you may need to google for some ready-made library in DLL, and download to use..
Re: parallel port
I presume the same syntax for parallel port interface using C would do the trick..
The function that u would have to use is _outb
More details are available from the help files of VC
Re: parallel port
use TvichW32
pm me if u can't get it
parallel port
hi,
I think the same syntax for parallel port interface used in C should work.
use _outb for the same
and outport ..
this should work..
