need sample program for pic18F4431
v_kumar
Full Member level 5
Full Member level 5
India
pic 18f4431
Need help
i am new to pic18f4431
i want to use this controller to control dc brushless motors
does anybody have any idea about the program,
or
any sample programs
so that i can start with it.
thanx in advance
pic18f4431 help
Application note AN899 which you can download from Microchip describes brushless motor control using 18FXX31 micros. Full source code in assembler is also available.
pic18f4431
thanx a lot mr btbass
i think this will help me a lot
If I have helped, please press my 'helped' button to improve my status in the forum.
I am writing a motor control progam at the moment using Pic18F4431.
It is in C using mcc18 2.4 compiler and mplab7. I use the ICD2 for debugging.
I am working away from home at the moment and only back at weekends.
So I can't answer unless it's a weekend.
I can edit my source code and share with you the core functions for driving the motor. Simple 6 step commutation. I can not share all as it is a commercial product and therefor copyright. The motor has 8 magnets, 4 pole pairs and uses Hall sensors at 60 degrees.
Motor control is quite big in industry at the moment with some esotoric methods being developed for greater power and efficiency such as Field Orientated Control using Clarke and Park transforms in real time using dsp based proccessors. (dsPic)
