mqblue
Newbie level 2
PLL solution help
Hi guys,
I am seeking a PLL scheme that works at about 2.5GHz and can lock the frequency as well as the phase within 1 us. I think maybe many PLLs can do this. but the special thing is that the current system use an universal 48MHz crystal and we can not apply the frequency changes directly on this crystal. Maybe we can only change division factor N to achieve this adjustment.
And here is the problem, actually in our system, we do not need PLL that with a big turnable range, we have known the frequency offset will be within 100 ppm. However, what is critical is we require the PLL could achieve the high resolution, which maybe within 1 ppm. I read some literature about fractional-N pll but find it really slow compared with the requirement of our system, if we use many bits of input words to get finer resolution.
So, in sum, we need a "PLL" that have a high resolution (within 1 ppm), fast locking time (within 1 us) and with the reference clock of 48 MHz from a universal crystal. The only good thing is that we know the frequency offset is always within a very small range, so we did not need a very large tunable range for this PLL. Therefore, with regard to this kind of requirement. What kind of PLL scheme or special solution shall I take ?
Thank you all in advance. Very appreciate for any of your help.
Qian[/b]
Hi guys,
Qian[/b]
