Need matlab script to import touchstone file - .snp
peleda
Full Member level 1
Monte Carlo
matlab touchstone
does anybody have a script or mfile that imports the data from a touchstone file into matlab?
i would like this for any arbitrary number of ports.
thanks,
matlab touchstone importer
Hi
I have used such script.
But I need some time to find one in my *.zip's
    peleda
view touchstone file
Matlab imports tocuhstone formated s-parameter directly in RF Toolbox..
matlab read in touchstone files
it only reads 1 port / 2 port network, I believe.
Added after 11 minutes:
dingjingfeng said:
1st Link = Not what I wanted.
2nd Link = I saw that, read too fast, overlooked it. I tried it again, and yes, it does have what i am looking for, but it does not work properly.
Thanks
touchstone file
there is a RF toolbox in the matlab help section
you will find straight example there
Nathan
Reactions: kayaoo
    kayaoo
rf toolbox import touchstone
This is a function i've written for importing touchstone snp files..
Hope it will help:)
does anyone know of an *.m file that removes the 99 port restriction (I need to import a 120-port file) ? Thanks
It is working! thank you very much!!:)
Re: rf toolbox import touchstone
Good post. However, you forgot to include the frequency component on the output file i.e. the ouput is only the four S parameters without frequency
hi, i am a bit new to matlab, can yo share an example how to use this function to read the .snp file
it seems has a problem when the number of ports are bigger 2. QQ图片20140220225206.jpg
