need information about large signal analysis
seantan85
Newbie level 3
Newbie level 3
singapore
Hi guys!
Can u guys tell me more? I know about small signal analysis well. But i dunno about large signal. Thank you!
Added after 1 hours 19 minutes:
Guys, my next question is when we apply large signal analysis, will the biasing for the mosfet be affected ? Does large signal analysis also affect dc analysis?
Large signal analysis
In large signal analysis your transistor has different mode and need to be considered.
you can google this
Re: Large signal analysis
seantan85 said:
Hi guys!
I am afraid both answers (see above) will not help too much.
Let me try it:
1.)For small signal analysis your circuit is assumed to be ideal and LINEAR ! Therefore, you can apply 1000 volts to the input of a transistor stage - and you get 50000 at the output (if the small signal gain is 50)
2.) For large signal analysis you have to call the TRANSIENT analysis. Now, all non-linear effects of the circuit (as far as they are modelled) are taken into account. As a result - you will see signal distortions and limiting effects due to the power supply rails.
Was this your question ?
