Need information about designing CMOS OPAMP in 0,35 µm technology
sykab
Member level 2
Member level 2
Hi!
I’m trying to design, in Cadence, a single-ended CMOS AMPOP in technology 0,35 µm with a Bandwidth of 100MHZ. I'm thinking to design a simple OTA but I haven't decided yet.
I would like to ask if someone can give me or advice me some kind of information/book to help me:?:
Thanks
Re: CMOS OPAMP 0,35 µm
go for telescopic cascode structure followed by a class AB buffer if you want to drive heavy cap loads and low resistive loads, and also swing.
Telescopic would be more efficient than a folded cascode.
all the best
    sykab
It is up to the load and your application. Cascode OTA is a good choice, but OPAMP can also be designed. Just use two stage.
    sykab
I want to do a current source which specifications can be seen in the image.
Thanks for your reply. :D
i advice u first stage folded cascode (PMOS as input) and second stage is CS (sure NMOS the input), this circuit gives u low in settling time and high gain with phase margin
regards
    sykab
regards
What's the meaning of "CS".
Thanks for you reply
CMOS OPAMP 0,35 µm
CS maybe is common source amp.
But the Bandwidth of 100MHZ is too large. Is it the unit gain bandwidth, but not the -3dB bandwidth.
I think it is hard to design an OTA with 100MHZ -3dB bandwidth. It will need a very large bias current to get a large gm.
Best regards!
    sykab
Best regards!
Yes, CS should be common source... it makes sense.
Thanks.
