swordz60
Newbie level 6
Hello guys,
I wanted to order this neat ADC breakout board from sparkfun, which employs a PCM1803 chip to do the conversion. However, it is not available in my country and it seems to be discontinued elsewhere too. But I managed to get my hands on the PCM1803 chip itself, so I'd very much like to know whether I can make a breakout board of my own using this chip.
The reason I want to do this is because I have this 2004 Volvo S40, which has no aux input in its radio. So I found this neat tutorial https://forums.swedespeed.com/showt...AUX-in-for-your-V50-basic-sound-system/page19 on how to retrofit the cd player of this car with an aux input by using the before mentioned sparkfun PCM1803 breakout board.
I don't have any experience with this kind of chips, but I have several years of experience on working with Atmegas and arduinos, so I just need a couple tips in order to know what I'm doing. So my question is this: what other components do I need to use with this chip so that it would work correctly?
Would it suffice to add capacitors, resistors and supply the correct voltage to the chip as it's shown in the schematic:
I mean, do I need to connect anything to pins 7-12, 15-20 or is it optional?
Thank you in advance for all and any comments that might be helpful.
