itsfanidotcom
Member level 5
HI THERE, I NEED TO KNOW THAT I WANT TO SAVE MY VALUES FROM MICROCONTROLLER AT89C51, THROUGH PARREL PORT, AND WHEN THE MICROCONTROLLER IS TURNED OFF THE VALUES SHOULD BE SAVED ON THAT CHIP AND WHEN THE POWERED IS TURNED ON THE SAME VALUES CAN BE FETCHED AGAIN FROM THAT CHIP.. I NEED TO KNOW WHICH IC SHOULD I USE.MODEL NO. etc..LIKE NVRAM.
I NEED A VERY SMALL MEMORY LIKE TO STORE A ANY 5 DIGIT NUMBER...THANKS..
