bcro
Newbie level 6
Hello. I work in an optics lab and am seeing evidence of instability in a laser's wavelength due to noise from the power line (120V, 60Hz). In a (successful) effort to clean up both the power and the ground lines, I have things hooked up as follows:
Outlet-->UPS-->Transformer-->Laser, (Config. 1)
where:
UPS = Tripplite SU750XL (on-line, double-conversion UPS)
Transformer = Tripplite IS250 (Isolation Transformer)
This cleans up the power nicely, but the instability in the laser only goes away when I unplug the UPS from the outlet:
XXX-->UPS-->Transformer-->Laser. (Config. 2)
I'm afraid I don't know details about the electronic internals of the laser system, but could any of you enlighten me on the difference between Config's 1 and 2? In either case, the 120V sine wave is just that generated by the UPS, and the Transformer is still there cleaning up the ground line. What's changing when I unplug the UPS?
Thanks a bunch.
where:
Thanks a bunch.
