need help with this nice math problem
jota
Newbie level 6
Newbie level 6
A coin with p{h}=p-1 is tossed n times. Show that the probability that the number of heads is even equals 0.5[1+(q-p)^n]
I appreciatte your any of your valuable contributions.
Thanks
Does p{h} mean p{Heads}? What is q?
p-heads
q-probability of not happening hats-(tails)
thanks
Added after 4 hours 55 minutes:
corection to the problem
A coin with p{h}=p=1-q is tossed n times. Show that the probability that the number of heads is even equals 0.5[1+(q-p)^n].
I found a hint for this problem. The hint is saying that we should write down the binomial theorem expansions of (q + p)^n and (q – p)^n, then add them together.
This would eventually result in expected solution-- 0.5[1+(q - p)^n]. The only problem is, I can not get to this expected solution. I need you help.
That's brilliant! Yes, the sum of all the even terms is just ((q+p)^n + (q-p)^n)/2, which is exactly your answer.
where do you get this 1 from? 0.5[1+(q-p)^n]. [/b]
p+q sure equals one as it conveys all the probabilities
