skitzin
Hi guys, first time poster and new forum member
Was hoping to get some help with nodal analysis of a circuit I have come across as an extension question in my class tutorials.
This is the circuit here: https://i.imgur.com/i4cY8B7.png
I'm looking to find the set of NODAL equations that mathematically describes the circuit. From there use Cramers Rule and Circuit Theory to solve for the voltages at the NODES 1 to 4 and then using these voltages at each node calculate the current for nodes 2 & 4.
I expect that the nodes 2 and 3 are not significant since they are outside the node? I.e. that I'd ignore the outside part?
Any help you guy can give would be greatly appreciated
For example for node 1 I got the equation as:
-12 + (V1/2k Ohms) + (V4/2k Ohms) = 0
Node 4: -2 + (V6/2k Ohms) - (V5/4k Ohms) = 0
