Need help with MATLAB code - Basics of communication engineering
userXY
Junior Member level 1
I need help with the following:
Write a program in MATLAB for plotting amplitude and phase spectre of a rectangular signal (see the first image) in the following cases:
1) A=1V,T=1s,θ=0.2s
2) A=1V,T=2s,θ=0.2s
3) A=1V,T=2s,θ=0.4s
Plot a power spectre.
What amount of power is situated by the first zero of envelope?
Describe the qualitative influence of period and duration of pulse on amplitude spectre.
Modify the program to obtain amplitude and phase spectre of triangular signal (see the second image).
Draw a power spectre.
Perform the comparative analysis of these signals considering the spectral efficiency.
1) I have the following code:
%Rectangular signal
A=1;T=1;tau=0.2;
alpha=tau/T;
num=fix(1/alpha); %number by the first zero of envelope
n=-3*num:3*num; %number of components for plotting
Cn=A*alpha*(sinc(n*alpha));
subplot(2,1,1)
stem(n*2*pi/T,abs(Cn));
title('Amplitude spectre');
xlabel('Angular frequency[rad/s]');
ylabel('|Cn|');
grid
subplot(2,1,2)
y=sign(n);
p=angle(Cn+eps);
stem(n*2*pi/T,(y.*p),'r');
title('Phase spectre');
grid
   k=-num:num;          % first spectre arcade
   Ck=A*alpha*(sinc(k*alpha));
    s=sum(abs(Ck).^2);   %power evaluated by Parselav's theorem
    eta=s/(A*A*alpha)   % coefficient of power efficiency of the first spectre arcade
% Triangular signal
figure
subplot(2,1,1);
Cn1=A*alpha*((sinc(n*alpha)).^2);
stem(n*2*pi/T,T*abs(Cn1),'linewidth',2);
ylabel('|Cn|');
grid
subplot(2,1,2)
y=sign(n);
p=angle(Cn1+eps);
stem(n*2*pi/T,(y.*p),'r','linewidth',2);
grid
 k1=-num:num;
    Ck1=A*alpha*((sinc(k1*alpha)).^2);
     s1=sum(Ck1.^2);    %power
Code graph results:
1) Rectangular spectre
2) Triangular spectre
Question 1: How to plot amplitude and phase spectar of rectangular signal in 3 cases:
1) A=1V,T=1s,θ=0.2s
2) A=1V,T=2s,θ=0.2s
3) A=1V,T=2s,θ=0.4s
Question 2: How to plot power spectre of rectangular signal?
Question 3: How to determine what amount of power is situated by the first zero of envelope (for rectangular signal)?
What amount of power is situated by the first zero of envelope (for rectangular signal)?
How to describe the qualitative influence of period and duration of pulse on amplitude spectre (for rectangular signal)?
Question 4: How to plot power spectre of triangular signal?
How to perform the comparative analysis of rectangular and triangular signal considering the spectral efficiency?
Note: This is not homework. I am practicing for exam.
