Elsewhere I have been reading the data/dirty sheet and you/I should be able to implement a 'method' that avoids WebBench. I have to sign up with contact details to some broken thing that uses 'Flash' so some sales rep can badger me? I think not!
4 GND Circuit Ground Ground reference for all internal circuitry
Know what? I prefer to officially register knowing someone might call rather something barely legal that happened with another manufacturer - I checked a step-up IC from TI, whre the recommended inductor was from Wurth Electronics.
There was a mistake with the p/n so I only entered Wurth's website, no registration, no nothing - the next day I got a call from their local representant.
This is spyware, not just a plain cookie.
Regarding the different PFETs: if the circuit uses a discrete current sense resistor, then the Rdson of the PFET doesnt matter. Using a discrete current sense resistor is always better in terms of noise rejection and performance because that resistance is stable over temperature. However, a PFET with a big gate charge (say over 40-50 nC) could cause problems by slowing the rise and fall times. If the rise time is too slow, the current limit circuitry can get confused.
JMini wrote:
> Does anyone have a way to approximate and RMS voltage from a PWM signal.
> I want to regulate the RMS voltage sent to a lightbulb, but do not have the
> room for the inductor and capacitor required to carry 20+ amps of current. I
> need to feedback a voltage to the PWM controller that is proportional to the
> RMS voltage of the output. I don't need an EXACT RMS conversion, rather a
> ratio would be fine since I can adjust the actual voltage fed back to the PWM
> controller via a resistor divider. For this current design, it will be
> operating at about 40kHz.
square-wave, duty cycle D = Ton/Toff
RMS = peak*sqrt(D)
Cheers
Terry
*Dec 12, 2005
*Doc. ID: 76943, S-52519, Rev. B
*File Name: Si7461DP_PS.txt and Si7461DP_PS.lib
.SUBCKT Si7461DP 4 1 2
M1 3 1 2 2 PMOS W=9986635u L=0.25u
M2 2 1 2 4 NMOS W=9986635u L=0.45u
R1 4 3 RTEMP 46E-4
CGS 1 2 4400E-12
DBD 4 2 DBD
.MODEL PMOS PMOS ( LEVEL = 3 TOX = 5E-8
+ RS = 52E-4 RD = 0 NSUB = 1.3E17
+ KP = 3.6E-6 UO = 400
+ VMAX = 0 XJ = 5E-7 KAPPA = 5E-2
+ ETA = 1E-4 TPG = -1
+ IS = 0 LD = 0
+ CGSO = 0 CGDO = 0 CGBO = 0
+ NFS = 0.8E12 DELTA = 0.1)
.MODEL NMOS NMOS ( LEVEL = 3 TOX = 5E-8
+NSUB = 3E16 TPG = -1)
.MODEL DBD D (CJO=470E-12 VJ=0.38 M=0.30
+RS=0.1 FC=0.5 IS=1E-12 TT=6E-8 N=1 BV=60.2)
.MODEL RTEMP RES (TC1=12E-3 TC2=5.5E-6)
.ENDS
*Dec 12, 2005
*Doc. ID: 77478, S-52519, Rev. B
*File Name: Si7465DP_PS.txt and Si7465DP_PS.lib
.SUBCKT Si7465DP 4 1 2
M1 3 1 2 2 PMOS W=2036637u L=0.25u
M2 2 1 2 4 NMOS W=2036637u L=0.45u
R1 4 3 RTEMP 39E-3
CGS 1 2 1000E-12
DBD 4 2 DBD
+ RS = 6E-3 RD = 0 NSUB = 1.2E17
+ KP = 3.5E-6 UO = 400
+ VMAX = 0 XJ = 5E-7 KAPPA = 7E-2
+ IS = 0 LD = 0
+NSUB = 2E16 TPG = -1)
.MODEL DBD D (CJO=200E-12 VJ=0.38 M=0.27
+RS=0.1 FC=0.5 IS=1E-12 TT=6E-8 N=1 BV=60.5)
.MODEL RTEMP RES (TC1=7E-3 TC2=5.5E-6)
.ENDS
I did tested the SI7461 which at least brought into the completely dead circuit some life.
Today, I installed by mistake a very small value Vcc capacitor. The recommended value is 0.47-1uF and by mistake I installed a 2.7n. Can't understand why, but the circuit started to work over the entire input range with a stability never obtained before.
CVCC: The capacitor at the VCC pin (from VIN to VCC) provides not only noise filtering and stability for the VCC regulator, but also provides the surge current for the PFET gate drive.
Sometimes when a hobby becomes a profession you stop enjoying it.
In earlier times I would sit and find where the problem is, but here I am working on a project with tight time schedule, I can not loose another week on it.
Genome, you are great, I really appreciate your efforts
Emanuel
Interesting simulation, it very much shows your point and justifies the RC addition at the sensing opamp you first came out with a few days ago.
* C:\spice\emmr\ton.asc
S2 0 SET N006 REF CMP
VREF REF 0 PULSE(0 1.25 0 2.5m 10n 1 5)
VDD N003 0 15V
RF VOUT N006 86K
RG N006 0 10K
LFILT N001 VOUT 100µ
CFILT VOUT N002 470µ
RESR N002 0 25m
RLOAD VOUT 0 6R
S1 N001 VIN DRV 0 MSW
D1 0 N001 DID
VIN VIN 0 15
R1 N003 SET 1K
S3 0 N004 CLR 0 MSW
R2 VIN N004 100K
C1 N005 0 100p
S4 0 DRV N005 N008 CMP
R3 N003 DRV 1K
V1 N008 0 5V
R4 N005 N004 10R
A4 SET R 0 0 0 0 CLR 0 SRFLOP Vhigh=15 Vlow=0 Td=50n
R5 N003 R 1K
S5 0 R N005 N007 CMP
V2 N007 0 100m
.model D D
.lib C:\Program Files\LTC\LTspiceIV\lib\cmp\standard.dio
.tran 0 11m 0 uic
.MODEL CMP SW(RON=10m ROFF=1E9 VT=0)
.MODEL MSW SW(RON=10m ROFF=1E9 VT=5)
.MODEL DID D(RON=10m ROFF=1E9)
.backanno
.end
Ignoring the mention of the soft start in the data sheet consider the one shot.
When you first apply power the IC will say 'Output Low better trigger the one shot'. If it does not continue to do that, or maintain the PFET on under control of the current limit, until it comes into regulation then it never will get into regulation. Effectively there will be one output pulse and then 'game over'.
One thing that arises is that as far as I can see, without taking other action, the circuit as described in the data sheet might suffer from a condition whereby it does not start up or at least not reliably.
