Each is 8 pin. The labels are not at a high enough resolution to read.
If you will post a close-up photo, someone here might be able to identify the IC's.
If your camera does not focus at that short a distance, then it will work for you to shoot through a magnifying glass. It may require several tries to get a sharp image.
