Need help with DRC errors in EAGLE CAD.
at89atbits
Member level 1
Member level 1
dimension.jpgdrill size.jpgoverlap.jpgstop mask.jpgstop mask.pngstop mask1.jpgwidth.jpg
I am getting a few DRC errors in eagle CAD
I just want to know if they can be ignored or fixed.
1) Dimension: I have used the 3.5 mm jack kibrary provided by sparkfun
However on Design Rule Check it is showing the dimension error.
Should I make any amends or it is fine to ignore this error?
2) Drill Size: I didn't quite understand what exactly is wrong here.
3) Overlap: Here wire of the same signal is overlapping with the pad and the via.
Is it fine to ignore this error or I need to make amends?
4) Stop mask: I am getting this error in two of the libraries I myself have made.
Is it fine to ignore the error? Or is it necessary to change the layer from tplace to tdocu?
5) Width: The ICs I am using have the pad width of around 8~9mil.
So accordingly I have kept the wire width to 9mil as well.
Also the operating current is in micro amperes.
So is it still necessary to increase the width of the wires?
Your images don't show the actual error report.
1) Looks like it can be ignored.
2) not sure here either - what is it saying is the error?
3) I would not want a hole through my SMT pads, I'd move it if I was doing this.
