Need help with DC to DC current buck boost converter
tanky321
Member level 1
Member level 1
DC to DC Buck Boost
Im trying to design a simple DC-DC current controlled buck boost converter, and im having a tough time. I calculated the inductor value by using this eq. L=Vin^2/(10f*Iout*Vout)
Where Vin= 12V Vout= 6-18V (used 18.) Iout= 1Amax f=200kHz
I can get the converter to boost just fine, up to 28V or so. But i cant get it to buck what so ever. No matter what the pulse width.
Here's the schematic, does anything stick out?
Thanks,
Andrew
DC to DC Buck Boost
If you intend the voltage across R1 to be the output voltage of your circuit, you should use a differential voltage probe. You are measuring V1 + Vout now.
Re: DC to DC Buck Boost
Thank you, I will try that!
