kcinimod
Member level 3
library ieee;
use ieee.std_logic_1164.all;
entity counter is
port(
clk_in : in std_logic;
data : in std_logic;
enable : in std_logic;
dout : out std_logic;
trigger : out std_logic
end counter;
architecture count of counter is
signal data_sync : std_logic_vector(1 downto 0);
signal pre_count : integer;
signal pre_count_1 : integer;
signal pre_count_2 : integer;
signal data_count : integer;
begin
process(clk_in)
begin
if rising_edge(clk_in) then
data_sync <= data_sync(0) & data;
end if;
end process;
count_proc : process(enable, clk_in, data_sync(1))
begin
if enable = '0' then
data_count <= 0;
pre_count <= 0;
pre_count_1 <= 0;
pre_count_2 <= 0;
elsif rising_edge(clk_in) then
if enable = '1' then
pre_count <= pre_count + 1;
end if;
end if;
if rising_edge(data_sync(1)) then
if (data_count = 0) then
pre_count <= 0;
data_count <= data_count + 1;
elsif (data_count = 1) then
if (pre_count > 5) then
pre_count_1 <= pre_count;
end if;
elsif (data_count = 2) then
pre_count_2 <= pre_count;
data_count <= data_count - 1;
end if;
end if;
pre_count <= 0;
end if;
end process;
compare_proc : process(clk_in)
begin
if (data_count = 1 and enable = '1') then
if (pre_count_1 > pre_count_2) then
dout <= '1';
trigger <= '0';
elsif (pre_count_1 < pre_count_2) then
dout <= '0';
trigger <= '0';
end if;
else
trigger <= '1';
end if;
end if;
end process;
end count;
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at data_count_1[31]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[31]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[30]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[29]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[28]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[27]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[26]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[25]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[24]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[23]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[22]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[21]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[20]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[19]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[18]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[17]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[16]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[15]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[14]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[13]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[12]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[11]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[10]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[9]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[8]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[7]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[6]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[5]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[4]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[3]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[2]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[1]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":47:2:47:3|Found combinational loop at data_count_1[0]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[31]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[30]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[29]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[28]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[27]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[26]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[25]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[24]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[23]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[22]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[21]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[20]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[19]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[18]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[17]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[16]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[15]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[14]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[13]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[12]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[11]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[10]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[9]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[8]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[7]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[6]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[5]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[4]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[3]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[2]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[1]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_1[0]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[31]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[30]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[29]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[28]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[27]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[26]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[25]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[24]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[23]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[22]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[21]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[20]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[19]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[18]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[17]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[16]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[15]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[14]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[13]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[12]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[11]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[10]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[9]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[8]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[7]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[6]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[5]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[4]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[3]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[2]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[1]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop at pre_count_2[0]
@W: CL169 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":27:8:27:9|Pruning register data_sync(1 downto 0)
@W: CL159 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\qrng.vhd":7:8:7:11|Input data is unused
@W: BN132 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Removing user instance count_proc.pre_count_2_1[31:0], because it is equivalent to instance count_proc.pre_count_1_1[31:0]
@W: BN132 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":74:23:74:47|Removing user instance compare_proc.un26_data_count, because it is equivalent to instance compare_proc.un25_data_count
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[0]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[1]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[2]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[3]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[4]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[5]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[6]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[7]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[8]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[9]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[10]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[11]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[12]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[13]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[14]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[15]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[16]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[17]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[18]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[19]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[20]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[21]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[22]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[23]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[24]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[25]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[26]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[27]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[28]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[29]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[30]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":34:8:34:9|Found combinational loop during mapping at net count_proc\.pre_count_2_1[31]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[0]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[32]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[1]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[31]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[2]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[30]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[3]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[29]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[4]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[28]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[5]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[27]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[6]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[26]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[7]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[25]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[8]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[24]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[9]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[23]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[10]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[22]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[11]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[21]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[12]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[20]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[13]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[19]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[14]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[18]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[15]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[17]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[16]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[16]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[17]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[15]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[18]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[14]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[19]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[13]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[20]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[12]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[21]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[11]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[22]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[10]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[23]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[9]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[24]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[8]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[25]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[7]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[26]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[6]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[27]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[5]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[28]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[4]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[29]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[3]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[30]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[2]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.data_count_1_6[31]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net un2_data_count_1[1]
@W: MO161 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":69:8:69:9|Register bit dout is always 1, optimizing ...
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_8
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_9
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_10
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_11
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_12
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_13
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_14
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_15
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_16
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_17
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_18
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_19
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_20
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_21
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_22
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_23
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_24
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_25
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_26
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_27
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_28
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_29
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_30
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_31
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_32
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_33
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_34
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_35
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_36
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_37
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_38
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":50:32:50:47|Found combinational loop during mapping at net N_39
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.un7_data_count_6_0_RNIKAITK
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.un7_data_count_6_0_RNIA5PEA
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.un7_data_count_6_0_RNILIC75
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.un7_data_count_6_0_RNI8L4R91
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.un7_data_count_6_0_RNIGA9MJ2
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\qrng.vhd":48:3:48:4|Found combinational loop during mapping at net count_proc\.un7_data_count_6_0_RNI0SKK
@W: MT420 |Found inferred clock counter|clk_in with period 5.00ns. Please declare a user-defined clock on object "p:clk_in"
