swen_s
Member level 1
![Member level 1](/styles/images/ranks/dlevel1.gif)
What is the difference between the two text origins "Component Name" and "Component Name 2" ?
Do they have the same value?
I found an answer on the net. Translated it to english with google translate![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
You can add two names of components that can coexist in two different positions on two
different layers (eg screen printing (Silkscreen) and equipment (Assembly)). Both names
"Component Name" and "Component Name 2" will be identical in value. Changing one
the other change automatically.
The position of the second component name defaults to the component origin (origin
"(Component)").
It is possible to control the position by adding a specific origin called "Component
Name 2 "when editing or creating PCB component.
"(Component)").
