Fan174
Member level 2
someone can tell me whats happening in the code as I can understand it has written to control the speed of DC motor
FILE NAME: dcmotor.c
CHIP TYPE: AT89C51
CLOCK FREQUENCY: 12MHZ
IDE: VSMStudio
COMPILER: IAR for 8051
TIME: September 2010
#include "ioAT89C51.h"
#include "intrinsics.h"
// Define P3 pins
#define Inc (P3_bit.P3_4)
#define Dec (P3_bit.P3_5)
#define Dir (P3_bit.P3_6)
#define PWM (P3_bit.P3_7)
// Define new types
typedef unsigned char uchar;
typedef unsigned int uint;
void delay(uint);
void main(void)
{ int speed;
// Select initial direction and speed.
Dir = 1;
if (Dir)
speed = 400;
else
speed = 100;
// Main control loop
while(1)
{ if(!Inc)
// Increase speed
speed = speed > 0 ? speed - 1 : 0;
if(!Dec)
// Decrease speed
speed = speed < 500 ? speed + 1 : 500;
// Drive a PWM signal out.
PWM=1;
delay(speed);
PWM=0;
delay(500-speed);
void delay(uint j)
{ for(; j>0; j--)
{ __no_operation();
