chipsnsystems
Hi Friends,
I have built a PPM encoder and decoder circuit and I am planning to use it to control a home built model aircraft. Basically the PPM encoder generates a PPM signal that depends on the position of 4 POTs. So its basically a four channel PPM.
I have tested the circuit and its able to change the position of the four servos that are connected to the decoder in accordance to the position of the corresponding POTs shaft. The only thing I now need to add to this circuit is an RF transmitter and receiver.
I have read elsewhere on the web that the RF receiver's AGC will add noise to the incoming PPM frame during the time when the PPM signal goes low or high for longer than a few milliseconds. Since the RC PPM frame pauses for nearly 10 milliseconds between each frame, I am worried that I might encounter the said AGC problem? kindly help me out with the following two questions. Thank you :smile:
1) Can I use readily available off the shelf RF modules after inverting the PPM frame or are they unsuitable for this task?
2) Do you think inverting the PPM frame will help to keep the AGC from adding noise by keeping the RF carrier on for most of the time?
