Need help to sense total weight of truck
sam_kevin
Junior Member level 1
Can somebody help me to sense the amount of weight the truck carries ?
What type of sensor i can use, where I need to install the sensor in the truck, Somebody please share your ideas.
Can I use Load cell to sense the dumpers weight ? Dumper weight is totally 25-30 tons.
Zasto : Can you please suggest me a load cell sensor
My car uses four of these : **broken link removed**
One by each wheel, between the chassis and each axle. They provide a signal that it is computed for self-levelling and could tell the load on the suspension if calibrated for known values.
