need help....to design a PCB
circuit
Full Member level 2
Full Member level 2
USA
I am a beginner to PCB design and am currently working a project where in I need to start layout of a PCB. We have Cadence PSD 15.0 installed. So where do I start ? I have been trying to read some of the tutorials. Please let me know of any good tutorials for beginners and other steps I need to follow ? Thanks in advance
Check ultracad at http://www.ultracad.com
Then you can visit some sites of pcb programs like Mentor, cadstar, etc.
Then check out eagle at http://www.cadsoft.de
all the above includes general guide lines and articles around PCB design.
Regards
thanks for the reply people. I am trying to read those tutorials and hopefully will start the work soon. thanks again.
I have some more questions. This is the problem. The PCB will contain a Image sensor chip and the output needs to be interfaced to a A/D evaluation board to start with. and then later on we wish to make a board with sensor chip, A/D and other components. the signal running from the sensor chip will be at around 15 - 20 MHz, how is the length of the trace dependant on this ? Also how do I decide upon the number of layers ?
Also what are the things I need to consider when interfacing the sensor chip and the A/D converter. The output of the sensor is analog differential. and the a/d takes in that. Thanks in advance !
Hi Circuit,
U can start learning the Allegro by the Training tutorial, search in this site, U will find the training materials for Candece PSD 15.0, Its really good for newbi in PCB from basic to advanced ( include simulation by using Cadence SpectraQuest 15.0 ). About your design, I think with speed from 15 to 20 Mhz, may be you no need to care about critical nets. however if U have recommend from Logic Designer for Placement components is better.
U can find the good document for Design from PCB express or on this site. very usefull.
Good Luck
Merry Crchismass
Concat
    circuit
No one is best, it's depend on your requirment!
I used Protel, PowerPCB & Cadence, each one has its own characteristic. Protel is easy to learn, PowerPCB is uesd for 4-8 layers PCB layout, if you want more layers PCB, Cadence is a good choice!
HI,
YOU CAN ALSO GET INFORMATION FROM www.mentorgraphics.com WEB SITE AS THEY ARE POSTING NEW TOPICS ON PCB DESIGNING.
AND
IF YOU NEED FOR TOOL OPERATING TUTORIALS I THING CADENCE SUPPORTS VERY WELL ON www.orcadpcb.com under discuss forum.
as mentioned ultracad web is also having good info.
regards,
anand
    circuit
thanks. i have one more question. How do I select the bypass capacitors (value ?) for my application ? I am having to layout a image sensor chip and an A/D converter chip. the sensor chip has separate analog and digital power supply and grounds. thanks once again !
edit:
what are all the things need to be taken care of to provide a clock input (say 20 Mhz) to a pin in the board...for ex, any capacitanes and resistors that should be added ?
