Need help to configure TFT display
UDHAY_KUMAR
Newbie
Newbie level 3
I need to use TFT LCD display 4DLCD-50800480-IPS. Please help me to configure with the following parameters.
HFP
HSYNC
HBP
VFP
VSYNC
VBP
RGB clock (in MHz)
RGB clock phase adjustment - options are 0, 1/4, 1/2, 3/4
The know parameters are
H active pixels - 800
V active lines - 480
RGB888
required maximum frame rate - 60fps
Please help me to understand the unknown parameters. The datasheet is attached here.
Thanks in advance
Udhay
  • 4DLCD_50800480_IPS_V1_4_update_20211006-2448932.pdf
Are you designing a product with processor, what is TFT interfaced to, what controller
is it using.....in short describe your project.
we are planning to use a 5" capacitive touch display with renesas RA8D1 microcontroller. The current version product we completed with an onboard HMI display from Nextion (NX8048P050_011). We are not satisfied with the touch response and display quality, so we are looking for a better display solution.
The RA8 microcontroller has the provision for 2 lane MIPI interface but unfortunately there is no display in the market for 5" 2 lane MIPI interface, so we decided to use ICN6211 MIPI to RGB bridge IC. The screen capture of ICN6211 configurator is attached here.
I need to input the "Basic settings" parameters to get the I2C configuration file. I'm not familiar with the RGB LCD display interface, so please help us to understand the setting for our specific display module.
Write your reply...
LaTeX Commands Quick-Menu:
