Need help - simulating envelope on advanced design system
jundi
Newbie level 5
Newbie level 5
help me about this...
What means this?i get when i simulate envelope on advanced desugn system
hpeesofsim (*) 331.200 May 6 2008 (built: 05/06/08 00:26:15)
Copyright Agilent Technologies, 1989-2008.
HB HB1[1] <G:\Documents\ads\gabung_prj\networks\receiver>
HB HB1[1] <G:\Documents\ads\gabung_prj\networks\receiver> Pin=(-50->-23)
Krylov-HB: 19 freqs, 64 time-samples.
Switching to source-stepping...
Attempting solution at `sourceLevel' value of 0.5:
Solution succeeded for `sourceLevel' value of 0.5.
Attempting solution at `sourceLevel' value of 1:
Solution succeeded for `sourceLevel' value of 1.
HB Env2[1] <G:\Documents\ads\gabung_prj\networks\receiver> time=(0 s->1 us)
Krylov-HB: 19 freqs, 256 time-samples.
COMPONENT : X14.R1.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R2.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R3.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R4.Z1P2 envelope bandwidth characterization
COMPONENT : X14.5.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R11.Z1P2 envelope bandwidth characterization
COMPONENT : X14.L1.Z1P2 envelope bandwidth characterization
COMPONENT : X14.L1.Z1P1 envelope bandwidth characterization
COMPONENT : X14.C2.Z1P1 envelope bandwidth characterization
COMPONENT : X14.C1.Z1P1 envelope bandwidth characterization
COMPONENT : X14.C3.Z1P1 envelope bandwidth characterization
COMPONENT : X14.L3.Z1P2 envelope bandwidth characterization
COMPONENT : X14.L3.Z1P1 envelope bandwidth characterization
COMPONENT : X14.L2.Z1P2 envelope bandwidth characterization
COMPONENT : X14.L2.Z1P1 envelope bandwidth characterization
COMPONENT : X14.R6.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R7.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R9.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R8.Z1P2 envelope bandwidth characterization
COMPONENT : X14.L5.Z1P1 envelope bandwidth characterization
COMPONENT : X14.C4.Z1P1 envelope bandwidth characterization
COMPONENT : X14.L8.Z1P1 envelope bandwidth characterization
COMPONENT : X14.L7.Z1P1 envelope bandwidth characterization
COMPONENT : X14.R33.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R28.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R27.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R26.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R25.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R24.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R23.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R21.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R20.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R19.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R18.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R17.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R16.Z1P2 envelope bandwidth characterization
COMPONENT : X14.C5.Z1P1 envelope bandwidth characterization
COMPONENT : X14.L6.Z1P1 envelope bandwidth characterization
COMPONENT : X14.R22.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R15.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R14.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R13.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R12.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R29.Z1P2 envelope bandwidth characterization
COMPONENT : X14.C7.Z1P2 envelope bandwidth characterization
COMPONENT : X14.L9.Z1P1 envelope bandwidth characterization
COMPONENT : X14.C8.Z1P1 envelope bandwidth characterization
COMPONENT : X14.R30.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R32.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R31.Z1P2 envelope bandwidth characterization
COMPONENT : X14.C6.Z1P2 envelope bandwidth characterization
COMPONENT : X14.R10.Z1P2 envelope bandwidth characterization
*** Solution FAILED for `sourceLevel' value of 0.5.
Attempting solution at `sourceLevel' value of 0.25:
Solution succeeded for `sourceLevel' value of 0.25.
Attempting solution at `sourceLevel' value of 0.75:
*** Solution FAILED for `sourceLevel' value of 0.75.
Solver convergence summary:
RHS:
0.5239 A at node X14.X6.FET1.g, harmonic index (1, 0)
0.4571 A at node X14.X6.FET1.s, harmonic index (1, 0)
0.1409 A at node X14.X6.FET1.g, harmonic index (2, 0)
Update:
0.01042 V at node X14.X6.FET1.g, harmonic index (1, 0)
0.01042 V at node X14.X6._net43, harmonic index (1, 0)
0.003028 V at node X14.X6.FET1.g, harmonic index (2, 0)
Solution:
8 V at node X5._net473, harmonic index (0, 0)
8 V at node X5._net465, harmonic index (0, 0)
8 V at node X5._net490, harmonic index (0, 0)
Simulation finished with errors.
Resource usage:
Total stopwatch time: 197.09 seconds.
Simulation terminated due to error.
