~MJS
Junior Member level 2
Hello All,
I am looking for an isolated voltage sensor (or Transducer) to measure the DC Voltage on my output. My applications is a Full-Bridge DC/DC converter: Vin=30V, Vout= 0 - 60V, Pout = 800W, and fs=200 kHz. (Note: the response of my sensor does not need to be that fast)
Digikey has LEM LV 20P for $36.6 , but this seems way to expensive for this application. Does anyone know of a cheaper component that would work for this application?
I have thought about using a hall-effect current sensor, with a high resistance, both in parallel with my output. The problem seems to be finding an IC that will measure current in the mA range and is isolated.
Any suggestions would be appreciated.
