also many PIC books i uploaded in www.freebookspot.com in Embedded System catagory.
Try to read all this it will clear your need architecture,programming and compiler
If you want to make simple application then start with 16f series and if you need your application with some flavor like USB or ethernet then start with 18F and if you want ur application need some dsp concept then start with dsPIC..
Also try to search free Seminar on Microchip web.. may next one held on near to your city.. thay will deliver it no prize and give you Development kit and tools CDs and Programmer all the things that need to start new project with Very low cost...
the 16F72 is not suported as is most pic chips **broken link removed**
Pickit 2 may be your answer.
The link above is the devices suported at this time. the list grows every few months. plus you can now use the pickit 2 as a Seial comms lead (usb to seial)
I would recommend you buy or borrow a Pickit 2, this can be bought for as little as $27 and if your lucky get a deal with 20 sample chips.
i have read your pic's datsaheet... you need to implement a master I2C and the pic16f72 SSP DON`t SUPPORT it!... (so SSPADD has the slave address in sleave mode = no use for interface with 24Cxx)
you should implment a master just by software...
microchip application note....
(AN554 - Software Implementation of I2C Bus Master.)
