monimi
Junior Member level 1
Hi, i'm having problems with the design of a development board based on Atmega32A which has USB connection.
The development board that i've been designing has the bootloader already loaded (it was loaded using SPI), the problem is that when i plug it on the USB port of my PC, it doesnt recognize the board, and it says that it is an UnknownDevice.
The data lines voltage should be 3.6V, but the output voltage is 4V. The components that i've been using are the following:
2 Resistors 68 ohm
1 Resistor of 1.5K
1 Resistor of 1M
2 Diodes 1N4148 (3.6V and 250mW)
1 Capacitor of 10uF
1 Atmega32A
in the attached files are the schematic, the board design and an image of the physical board. The connections between lines are checked already so there are not short circuits.
if some one could help me it would be really great, i have to finish this project as soon as i can but i have no idea what could be the problem. thanks in advanced.
2 Resistors 68 ohm
1 Resistor of 1.5K
1 Resistor of 1M
1 Capacitor of 10uF
1 Atmega32A
