need help on the toolkit TK3 programmer
Rambo55
Banned
Member level 3
Australia
I need a toolkit Tk3 Programmer Schematic and PCB as I have a PIC16F877A to program for the Digital IC Tester as the PIC16F877A need bit Configuration or can I use the software on Other Programmer the toolkit mk3 software will not work in XP Windows and Windows7 I Only have the 2 windows in my Hard drive how can I get the software to work in the windows
Here's a link to a writeup on the MK3 Programmer:
Attached are the original files from the magazine article:
Hope the info helps,
BigDog
  • tk3.zip
  • BoardLayout2.pdf
  • BoardLayout.pdf
  • SchematicMB.pdf
  • SchematicSB.pdf
By the way Rambo55, if you need to run a particular version of windows that is compatible with the MK3 Software, install VirtualPC or another virtualization program and install it on a virtual machine.
It's by far the easiest way to get around OS incompatibilities.
BigDog
