Need help on switched CMFB
prince_123
Junior Member level 2
I am making a residue amplifier for pipelined ADC on 65 nm node
Can any one tell me detailed working of switched CMFB
What will happen if there is an offset in the bias voltage set by the replica and actual bias voltage required?
Is there any way to ensure zero offset across all process cornets and temperatures?
U can see in 1)Razavi and 2) Baker
I don't tink it would be zero in all corners, but you can decrease it adequately. This paper includes a good research on CMFB:
"Analysis of Switched-Capacitor Common-Mode Feedback Circuit",
By: Ojas Choksi and L. Richard Carley,
TCAS II, 2003.
Thanks naalald
It will be really great if you can post that paper, I don't have IEEE access in my company.
Thanks once again
The paper is attached. Hope it helps you!
    prince_123
Its really useful
Thanks for help
