need help on setting up Hi-Tech with MPLAB !
donkey41
Full Member level 1
Full Member level 1
Pakistan
16f877 build failed trace
hello everybody,
I think i need some help in integrating HT picc compiler with mplab.
I have set up MPLAB for HT PICC but even with compiler supplied sample code for LED.C it does not work and exits as follows:
Executing: C:\HT-PIC\BIN\PICC.EXE -Q -MPLAB -C -16F877 led.c -Oled.obj -Eled.cce -G
Halting build on first failure as requested.
BUILD FAILED
i have tried on both 6.xx and 5.7x version of MPLAB.
I have also tried on its own DOS mode, but it is very difficult to trace any messege there. Only thing which I can read is:
Exit status = 4
what is wrong ?
Is there any solution ?
thanks
PS:
I have read the small tutorial on www.microchipc.com and tried to setup, but the result was not successfull ...
Are you sure that your compiler is registered correctly ?
Ooops, I sent previous message unfinished.
Firstly, try from DOS window:
PICC -version
or
PICC18 -version
Secondly, I suppose that you can catch all messages from the command line version when you pipe them to some text file. Use something like:
C:\HT-PIC\BIN\PICC.EXE -Q -C -16F877 led.c -Oled.obj -Eled.cce -G > output.txt
and examine the file "output.txt" with text editor.
make sure you have set it up using the Project->Install language tool option in MPlab and set up the following enviroment variables on your computer
HTC_ERR_FORMAT Error[000 ] file %f %l : %s
HTC_WARN_FORMAT Warning[000 ] file %f %l : %s
I assume you have set the sample code up as a project and set the language tool suit to Ht Pic?
Then you should be able to build from mplab and get all output from the compiler into the build window.
:D
Don’t know exactly what the problem is in your case, but check this link for a great step by step instruction on how to integrate PICC with MPLab and create a project.
A lot of more info on this site as well, especially check the FAQ on PICC, there are some limitations and other stuff that is u need to know of when using it.
Se: https://www.microchipc.com/HiTechCtutorial/
regards Me
Any help on first question? I need it realy wey much.
Regards!
Correct HT-PIC Serial Number
Hello,
i was found this problem befor this time,downl load fss serial number generator from https://astalavista.box.sk word search "HI-TECH C"
and put Serial Number with only 5 digit
it is work correctly :wink:
Thank You
