I am doing line following robot as my mini project
we can add applications like pick and drop with line following.if so how to do it?
I have used metal castor wheel and it worked perfectly.for designing line following robot whether normal castor wheel is enough?either we should use plastic or metal?
I have used only one castor wheel(in the front side)how many needed to make the robot balanced?
