ssankurathri
Full Member level 3
hi
I am working for the first time with IBIS models. I found the ibis version of model and converted into spice model. the spice model looks like:
.subckt IO_01_T 100 4 300 400 500
*Connections Input Output VCC VEE Enable
** Referenced by:
** IO-1, IO-2, IO-3, IO-4, IO-6
** IO-7, IO-8, IO-9, IO-10, IO-11
** IO-12, IO-13, IO-14, IO-15, IO-16
** IO-17, IO-18, IO-19, IO-20, IO-22
** IO-23, IO-24, IO_25, IO_27, IO_28
** IO_29, IO_30, IO_32, IO_33, IO_34
** IO_35, IO_36, IO_37, IO_39, IO_40
** IO_41, IO_42, IO_43, TDI, IO_46
** TMS, TCK, IO_49, IO_50, IO_52
** IO_53, IO_54, IO_55, IO_56, IO_58
** IO_59, IO_60, IO_61, IO_63, IO_64
** IO_65, IO_66, IO_67, IO_68, IO_70
** IO_71, IO_72, IO_73, IO_74, IO_76
** IO_77, IO_78, IO_79, IO_80, IO_81
** IO_82, TDO, IO_85, IO_86, IO_87
** IO_89, IO_90, IO_91, IO_92, IO_93
** IO_94, IO_95, IO_96, IO_97, IO_99
*Model Version; typical
*DEFINE {RTF}= 45.095k ;1.366/0.616n
*DEFINE {RTR}= 36.282k ;1.221/0.443n
* Input Control
B1 820 0 V=V(100) & V(500)
B2 830 0 V= V(500) & ~V(100)
* Up and Down Ramps
*B3 300 850 I= V(830) > 1.2 ? 0 : V(300,850) / {RTR}
RB3 300 850 100MEG
*B4 840 400 I= V(820) > 1.2 ? 0 : V(840,400) / {RTF}
RB4 840 400 100MEG
C1 300 850 .01P
C2 840 400 .01P
S1 220 850 0 820 SMOD
S2 840 220 0 830 SMOD
.model SMOD SW RON=.1M ROFF=1E15 VT=-1.2 VH=.1
G1 8 400 2 8 1
R1 6 400 1
G2 300 8 8 3 1
R2 300 6 1
* Pull-up/Pull-down structures; typical
XPULL_DOWN 2 400 8 840 PULL_DOWN
XPULL_UP 3 300 850 8 PULL_UP
* Diode Clamps
XPOWER_CLAMP 6 300 300 6 POWER_CLAMP
XGND_CLAMP 6 400 6 400 GND_CLAMP
* Package Parasitics: typical
ROSNB 5 1 100
ROPKG 1 4 84.800m
COPKG 4 400 0.550pF
CCOMP 5 400 6.700pF
LOPKG 5 1 5.200nH
* Voltage Sources for measuring currents
*V5 6 5
*V6 8 6
*V7 220 8
.ENDS
.SUBCKT GND_CLAMP 3 4 1 2
* Connections Out+ Out In+ In
*AGndClamp %vd(1,2) %id(3,4) transfer
.model transfer pwl
+ fraction = FALSE, input_domain = 0.0, xy_array = [
+ -4.300 , -155.000m
+ -3.300 , -155.000m
+ -3.200 , -149.000m
+ -3.100 , -143.000m
+ -3.000 , -137.000m
+ -2.900 , -131.000m
+ -2.800 , -125.000m
+ -2.700 , -119.000m
+ -2.600 , -113.000m
+ -2.500 , -106.000m
+ -2.400 , -100.000m
+ -2.300 , -94.120m
The spice subcircuit consists of several subcircuits as shown above. Only one subckt is taken into consideration for simulation.
How to simulate multipel subckts in a single spice file?
any help on this would be much appreciated.
Regards
skr
Added after 2 hours 34 minutes:
hi
can anyone plz suggest what is the best ibis to pspice converter available?
Regards
skr
Added after 1 hours 38 minutes:
hi
does anyone have any idea on this following code functionality
.SUBCKT PULL_DOWN 3 4 1 2
APullDown %vd(1,2) %vd(3,4) transfer
.model transfer pwl fraction = FALSE, input_domain = 0.0, xy_array = [ -4.300 ,
+ -57.200m -3.300 , -57.200m -3.100 , -56.300m -2.900 , -55.300m -2.700 ,.....
Regards,
skr
** Referenced by:
* Input Control
* Up and Down Ramps
RB3 300 850 100MEG
RB4 840 400 100MEG
C1 300 850 .01P
C2 840 400 .01P
G1 8 400 2 8 1
R1 6 400 1
G2 300 8 8 3 1
R2 300 6 1
* Diode Clamps
ROSNB 5 1 100
ROPKG 1 4 84.800m
COPKG 4 400 0.550pF
CCOMP 5 400 6.700pF
LOPKG 5 1 5.200nH
*V5 6 5
*V6 8 6
*V7 220 8
.ENDS
.model transfer pwl
+ -2.300 , -94.120m
Regards
skr
hi
Regards
skr
hi
Regards,
skr
