need help of solving spike Vg induced by Vd on MOSFET.
G35
Newbie level 3
Newbie level 3
fet output spike
Here are my quesoins:
1. will Vd induce spike voltage (noise) at Vg for a MOSFET?
2. If so, how can I eleminate the spike voltage so that Vg is not effected by Vd?
formula to find vd in mosfet
In some high speed comparators, the influence from Vd to Vg is called "kickback noise". There are some techniques to reduce the kickback noise.
1.Neutralization Technique
2.Isolation Techniques, that means place preamplifier beforce the dynamic latch.
Google "kickback noise", you can find some papaers to deal with this problem.
sixth
    G35
how to reduce the voltage spike in mosfet
Thx for your post. However, I am not using it in a comparactor. I just use it in a brushless motor. The drain connects to a coil, which is connected to Vcc. And the source is connected to the ground. and gate voltage comes from an output of a microchip range from 0V to a turnon voltage. However, the gate voltage has some noise when it turns off the MOSFET, which is induced by the drain. is there any other motheds to eleminate the noise? I want the gate voltage goes to the 0V without swinging.
voltage spike get rid
Pararell a resistor to g and s
spike on low gate mosfet
G35,
yes, voltage spike on the drain can effect the gate voltage. The reason for this is the gate-drain (Miller) capacitance of the FET. Have you tried to limit the spikes on the drain by using a snubber circuit from drain to source? The snubber would either be a RC or a RC+diode circuit. Before putting anything else around the circuit I would try the snubber.
Best regards,
v_c
    G35
mosfet spiking
RC circiut is a good idea. However, it couldn't help at a high frequency because the drain is connected to a coil which connects to a PWM. Actually the spike is fine. What really causes the problem is the fall of the spike. It generates a swing and this swing affects the gate voltage. and I am trying to get rid of the voltage swing at the drain. Anyway, thank you guys for all your inputs.
mosfet spike
try to lower mosfet input resistance by resistor connected to gate source . Or better to use low output impedance buffer (current booster) before mosfet .
But what is the spike parameters - rise time, amplitute and others and type of mosfet you use?
