niks
Full Member level 3
![Full Member level 3](/styles/images/ranks/elevel3.gif)
need help @ MAX1840 ??
Hi
Im using MAX1840 level translator between two controllers. But im facing some problem with default status of the translator. Data pin is always pulled high because internal 10K pull resistor of 1840. But RIN(Reset In) and CIN (CLK In) pins are always at 2 - 2.4 V. Im keeping Dvcc @ 3.3 V and Vcc @ 2.8 V.
I verified if controller is driving on 1840 but that is not the case. Can anyone tell me what should be status of the 1840 pins.
~niks~
Hi
~niks~
