Need help in testing ADC
chicky
Newbie level 2
Newbie level 2
hi.
i need help in testing ADC. i am currently using a ADC0804 and quite confused in the different grounds at 2 different pins.
anyone with an ideal way or circuit of testing ADC, kindly please lent me a helping hand.
any help would be greatly appreciated. thanks.
The two different Grounds in ADC are
1) A GND - Analog Ground
2) D GND - Digital Ground
Ideally the Analog Ground and Digital ground in the Anlog Digital circuits are seperated for obtaioning noise immunity on analog lines
But while testing you can conncet the two grounds together
in the above datasheet there is basic ADC tester circuit available on Page 24
I guess that is the simples method to test your ADC
Digital and Analog grounds are separate grounds on the chip itself. In an application they should be connected together as close to the chip as possible. Idealy this should be the single ground point for the entire system, with the system analog and digtal grounds kept separate, and connected at the ADC chip.
