need help in socket programming
H_D_R
Full Member level 6
Full Member level 6
India
hello all,
i want to do socket programming in liunx using C.
i have knowledge of linux and C but not much more regarding networking.
can anyone please tell me from wher i can get the details to start the work in proper way and efficiently..
i need this book also..
please upload if any one found it..
book :: The Definitive Guide to Linux Network Programming by KEIR DAVIS, JOHN W. TURNER, AND NATHAN YOCOM
Thanking you all in advance...!!!
u can check the book written by Forouzan with the title tcp/ip networking.
Find "Unix Network Programming". It's good.
dipal_z said:
This is one of the best guide available on net related to socket programming https://beej.us/guide/bgnet/
thank to you all for replying..
the tutorial from beej has good material.
BTW, i was looking for book named "UNIX NETWROK PROGRAMMING- Interprocess Communications vol-2" by W. Richard Steven.
i have found one link but it is in .djvu format.
can any one please upload the pdf format of that or link for pdf format of this book.
thanking you all again...:D
I have it but it is over 70Mb. I tried p7zip but got an extension not allowed message.
How shall I send it? Is cutting the file up ok, or shall I just change the extension?
By the way, what is wrong with djvu?
thanks for your all respone..
i have checked some of codes from net.
i can understand little bit for server-client.
but still confusion is there i have to do practise on shell terminal.
so can you please tell me how to communicate the server client..
what should be the use of telnet..??
