Need help in PSoC ADCINC12 and INSAMP user modules
Bus Master
Full Member level 3
Full Member level 3
Just behind You ;-)
psoc adc
Hi all,
I'm interfacing a thermocouple (type K)to a CY8C26443 chip. Thermocouple to the INSAMP (Ref = AGND) then to the ADCINC12 (REFMUX = 2BG +/- BG). I've applied the (Correlated double Sampling and IIR software filter) to nuteralize the offset voltages and signal noise. The main problem is: i get a correct readings out of the ADC (-800 to +7FF). But, How to accurately convert this value to the corresponding millivolts? I'm a newbie to PSoC programming and i'm really confused. (N.B. REFLO = 1.3V, AGND = 2.6V, REFHI = 3.9V).
Please kindly advise ASAP as i've been stuck at this stupid point for the last 3 days.
Thank you very much for your time.
Yours,
insamp psoc
Hi
Here are my thoughts:
Since you are using a 12 bit ADC and assuming your swing is -5 0 +5 then
-5 volts = 0 ADC counts
0 volts = 2048 ADC counts
+5 volts = 4095 ADC counts
Then for the ADC count you have sampled
v = (5 * (x - 2048)) / (4096 - 2048)
    Bus Master
