Need help, Im looking for high dielectric ceramic material
kocha
Member level 1
Member level 1
maruwa m24
Hello all
Im looking for high ε low tanδ ceramic substrates ,
for antenna size reduction.
The parameter of the substrate sould be
ε>40 with dissipation factor lower then 0.002.
thanks in advance
Kocha
Re: Need help, Im looking for high dielectric ceramic materi
It seems that there is no commercial ceramic substrate with so high dielectric constant. The commercial ceramic substrate which is often used is Alumina with the dielectric constant of 9.8.
Dear burton
here are some links for high ε ceramic material:
http://www.heraeus-th.com/wch2/tfd/e_th_Techinfo.nsf/46A1A92B8A54B565C1256EF600242F7F/$FILE/CT707_CT765.pdf
But thus company dont have any material with low dissipation factor.
Regard
kocha
Reactions: sunyi
    sunyi
ceramic substrate we used are 9.2 ,27 or 65
    kocha
Dear Peak
Do you have a clue what is the dielectric loss (dissipation factor/tan delta) of the material.
I found a material at maruwa M24
the εr is 24 and the Q factor is 200000 what is the tan delta ?
thanks in advance
kocha
Many thin/thick film fabs offer high-K materials with low loss tangents. See page 6:
    kocha
Thanks madengr
you help a lot
KOCHA
