Need help for Xilinx ISE Ver 6 . How to run programm in it
moonnightingale
Full Member level 6
Full Member level 6
I have written this small code in it
module halfadd(sum,cout,a,b);
input a,b;
output sum,cout;
xor(sum,a,b);
and(cout,a,b);
endmodule
How can i run it and give my input as 0 or 1. I used xilinx several years back and now i have forgotten it. There is run option but when i click it it asks for file name
Plz help and and also tell me source where i can learn abt Xilinx Sofware utilization
hi
it is easy to run it you go to the project select the new project after you tik mark the test banch and give the name of test. after push the next button the run you project to give high low value their, other wise you installed the modelsim 5.8c ok. it is very helpful to you.
i will send it pls see it. and also the madelsim is give simulation.it also useful for you.
  • New Folder.rar
Yes i know Model sim is good software but i have to do my project in Xilinx software..
So i cannot afford to learn two softwares
can u send me some link for learning Xilinx ISE software
