89c450 mtk2
hi,
i am newbie in this forum as well as in microcontroller world.
I had a new DS89C450-k00 (Evaluation kit) with DS89C450 day before yesterday. But still i can not start it. I followed the instructions given in the quick start guide.
1) Connect the DC 6V–9V, center post positive power supply to the power plug J1.
2) Connect a DB9 straight-through serial cable between the PC COM1 port and connector J2.
3) Set DIP switches SW1.1, SW1.2, SW1.3, SW4.1, and SW4.2 ON. All other DIP switches should be OFF.
4) Turn power ON. All the LEDs should light except for the second from the right.
5) Open MTK. In the initial dialog box, select the type of processor you are using (DS89C430, DS89C440, or
DS89C450).
6) Select Options -> Configure Serial Port from the menu. Enter COM1 and 14400 baud.
7) Select Target -> Open COM1 at 14400 baud.
8) Select Target -> Connect to Loader.
Here all go fine. But when I select Target -> Connect to Loader , then either of the following messeges come-
"ÍLoader not responding
Unable to establish communication with target.
Check connection to target system or consult help files."
"Unable to establish communication with target.
When I try to start it in debug mode then the following messege comes-
"<0D><0A>
<0D><0A>
<0D><0A>
<0D><0A>
<0D><0A>
When I changed voltage of the adapter today then MTK showed
some garbage characters.
I am using-
1. 9v, 400mA adapter.
2. windows XP
3. tried both MTK2.2 and MTK 2.3
Please help me to solve this problem.
Thanks in advance.
