ardique
Junior Member level 2
Hi all,
I'm currently work on a 1kVA full-bridge single phase inverter with SPWM current control. However, during my testing on open loop with lower rating test (60Vdc, Rload = 11.6ohm, Irated = 3A), I have problem at my high side switching pair (Q3). Attached are the schematic, pcb layout design and the waveform that I measure on Vgs on Q2(pink color) and Q3(purple color). Since the problem is occurred at pair of Q2&Q3 that I'm working with. Please let me know what did I missed or wrongly do the connection.
I'm using CoolMOS power transistor (SPW35N60C3), MINMAX(MCW03-24D15), gate driver (TLP350).
Moreover, the spwm signal generated from DSP also affected by the distortion as shown in waveform.
Your cooperation is very much appreciated.
Thank you.
Thank you.
