Need HELP for 4-20mA to 0-1V converter using LM741/324/OP-07
staticshock
Newbie level 2
Newbie level 2
4-20ma to 0-1v converter
hey guys...:D:D
i'm stuck with this problem from a month...
the requirement is to convert 4-20mA of current in to variable 0-1V output....
using an OP-AMP is mandatory...:|:|
plz tell me the circuit diagram and the component values for each circuit using above OP-AMPs...(LM741 or 324 or OP-07)
i've tried it so much... but i couldn't get the expected results....:cry::cry
i've tried another threads but it's not that i wanted...
PLZ tell me as soon as possible...:cry::cry:
420ma op amps
As a general outline, use a 324, you may find it easier with more than one op amp.
Convert the 4 to 20 mA into 2 to 10V by connecting across a 500Ω resistor (or 1 to 5V across a 250Ω), buffer and subtract 2V (or 1V), apply to gain of 1/8 (or 1/4) and buffer the output. A lot of this can be done around only one of the op amps but I like to buffer outputs if I don't know what its driving. Also be aware that you may not be able to drive down to 0V.
