mudmuncher
Newbie level 2
Objective: to make a small motor turn a few rotations every 15 seconds.
The power supply is a 12 volt car battery. I need a timer that will send 12 volts to a small motor about every 15 seconds. I want the motor to turn a few rotations and stop. The motor is a 12v, 155 rpm, 0.4 amps, 4.6 stall amps. It might help to see the use of the motor I will be turning www.mudmuncher.net
Thank you for any help you can offer.
