need help: EAGLE gerber data file extension
ella1923
Member level 1
Member level 1
hi,
what are the file extensions of making EAGLE gerber data? (like top layer, bottom layer, top mask, bottom mask, drill etc.)
thanks
You can use what you like, but if you load the standard CAM processor files then look at each of the layers you will see the extension for each layer e.g. .ly2 for "Inner layer 2":
Keith
already found it with the cam processor and eagle control panel help..
---------- Post added at 18:03 ---------- Previous post was at 18:01 ----------
thanks for your reply keith
