Need help designing sawtooth generator
chuntzu
Newbie level 2
Newbie level 2
Hello
I am trying to design a class D amplifier and needs to find a way to generate a 2-500KHz sawtooth with approx 3v pk-pk, without using any generatorchip. I've tried searching the internet and simulated the circuits that I found, unfortunatly no one worked as I wanted
I will use the sawtooth to generate a PWM that will be amplified and then it will control the output FETs
Someone who has any suggestion?
/Oscar
Do you mean 2 Hz to 500 kHz, or 2 kHz to 500 kHz?
If ur using PSPICE to simulate a sawtooth generator i have a material.. jes a take a look at it.. it wud surely help u..
with regards,
using two comparators &a capacitor ,you can build a sawtooth wave.
