Need help designing a filter(active)
arunbhaskar
Junior Member level 3
I need help designing a opamp active low-pass filter.
I need the gain in the passband to be close to 1.
Passband cutoff frequency is 5Hz.
Transition band may go upto 50Hz.
I tried designing for above parameters using 2nd order sallen key filter. But that does not provide me unity gain for satisfactory frequency response. Can someone suggest a better circuit for the same job.
Try Texas Instruments Filter Pro software. It is free and easy to use.
You should be able to get the response you require - what is actually wrong with the response you get? Can you show your circuit and results?
Keith
Sorry, but this is no filter specification. I suppose, you mean a low pass filter, but how could we know which order?
The second "information" is useless without mentioning the required damping at 50 Hz.
I'm sorry. I forgot to mention
Stopband attenuation is atleast 20dB.
For such a small attenuation of only 20 dB (one decade above the corner frequency) a first order (passive) low pass is sufficient.
