need help debugging a MFC 7 prog
C++
Junior Member level 3
hi, i've attatched the project to this post, the left, right, up, and down functions (recursive) aren't working properly. the agent in this project is supposed to go around the maze (no walls, all rooms open, some have holes, there's 1 monster and 1 gold room) looking for the gold, but instead he goes around in a circle.
Thanks for ur help
void CWampusDlg::left ()
char temp[10] = "";
itoa (x, temp, 10);
start.SetWindowText (temp);
Sleep (speedVal);
itoa (y, temp, 10);
Sleep (speedVal);
if ((x != 0) && ((maze[y][(x-1)] != '<') && (maze[y][(x-1)] == '>') &&
(maze[y][(x-1)] != '^') && (maze[y][(x-1)] != 'V')))
at this point in the program i note that you use x and y values
? where do you get this value
1} they are never passed to the routine
2} they arent setup in the code within the routine so x and y will just equal zero
so it will go around in a circle as in your app zero is a one state
maybe the same for right routine
you must pass a value on
void CWampusDlg::left (int x,int y) etc...
with global values also used for things like arrays
it isnt a good idea to pass them around
the apps main threads
    C++
x and y are declared in the main class, every time the agent makes a move, x and y are updated using updateAgentPosition ().....anyways, i fixed the code, thanks anyways :)
