need help concerning sdcc software
the moon is back
Member level 2
Member level 2
hi, i've installed small device c compiler(sdcc) software, when i try to compile any code it's showing an error"fopen failed on file test.lnk"
what do you mean by this error, pls help me to sort out this problem.
thank u
First of all which controller you are using...
Then post your code also..
